> N20 a N26 - SULEV - 2.0 biturbo 245 KM benzyna, Różnice
Joker
post Fri, 22 Aug 2014 - 10:19
Czy zna ktoś różnice pomiędzy wersją silnika 328i N20 a 328i N26 SULEV? (chodzi o Super Ultra niską emisję).
Oba mają 180kW czyli te 245 KM jest.
W ETK niektóre części różnią się numerami - jak to jest w rzeczywistości?
duct tape
post Fri, 22 Aug 2014 - 18:46
A co SULEV-y robią na racingforum? huh.gif tu masz krótkie info po angielsku odnośnie M56 SULEV. Podejrzewam że N26 ma podobnie.
Specs of the M56 engine
HC block in the air intake system:
Hydrocarbon escape via the intake system is prevented due to the use of an additional carbon filter incorporated in the air filter housing and a "closed" throttle valve actuator.
Fuel system components:
All metal fuel system components (fuel rail, injectors, tank ventilation valve, etc.) are made of stainless steel and are fastened together using coupling type connectors.
Fuel tank and tank ventilation system:
The fuel tank, tank filler neck and evaporative canister are made of stainless steel. Both the fuel pump and fuel filter are completely sealed inside the gas tank and require a complete replacement of the gas tank if either the fuel pump or filter fail.
Crankcase ventilation system:
The crankcase ventilation valve is incorporated in the aluminum cylinder head cover.
System components used to achieve SULEV tailpipe emission requirements:
Dual down stream catalytic converters
"Warm up" catalytic converters – high cell density technology
Upstream oxygen sensors – wide band technology
Pistons – only 3mm fire land
VANOS – set to fixed position during start up for improved engine start
New style fuel injectors–4 hole design (5 bar fuel pressure)
Secondary air system with secondary air mass flow sensor used for improved monitoring of secondary air flow.
In addition SULEV models also incorporate a "Direct Ozone Reduction System". The external heat exchange surfaces of the radiator are coated with a catalyst which reduces the ozone in the ambient air drawn through the radiator.
Najbardziej kłuje w oczy ta część: Pistons – only 3mm fire land. Pewnie zatopili w nich stalowe wzmocnienia półek jak w tłokach diesli. Wg. mnie samo alu by się poddało. Podejrzewam ECOFORM lub nawet EVOTEC od Mahle.
Bibliografia:
http://en.wikipedia.org/wiki/BMW_M56
http://www.cn.mahle.com/MAHLE_China/en/Pro...asoline-engines
Joker
post Fri, 22 Aug 2014 - 21:02
CYTAT(duct tape @ Fri, 22 Aug 2014 - 18:46) *
Kupiliśmy takie 328i nie wiedząc, że jest jeszcze N26 zamiast N20, i części mogą być problemem, to wszystko.
A że ma również 245 KM to podejrzewamy, że oprócz eco-pieprzenia to ten sam motor w kwestii użytkowania.
jannek
post Thu, 28 Aug 2014 - 21:28
Silnik N26 dzieli okolo 95% podzespolow z N20.
Jak sam wspomniales zmiany maja na celu redukcje emisji spalin.
1. Zawor regulacji cisnienia na pokrywie zaworow jest z nia zintegrowany w przeciwnienstwie do N20 gdzie wystepuje jako wymienny element.
2. Dodatkowy filtr HC w Airbox'e (niewymienny oddzielnie)
3. Elektryczny aktuator turbosprezarki, taki sam jak stosowany w N20 od lipca 2012.
4. Wtryskiwacze takie same jak w N20 i N55, ale "recznie wybrane" sposrod juz przetestowanych, tak aby parametr zwany "leakage" byl <0.5mm3/min przy 20MPa
5. Inny software, majacy na celu szybsze podgrzanie katalizatora itd. Samo DME powinno byc takie samo jak to w N20 od lipca 2012.
6. Zmodyfikowana pompa paliwa (takie samo cisninie jak N20 ), wzmocnione przewody paliwowe, zmienione polaczenie przewodu paliwowego ze zbiornikiem paliwa.
Wszystkie te zmiany maja na celu zminimalizowanie wewnetrznych utrat/wyciekow paliwa.
7. Zmieniony pierwszy katalizator. Dwuelementowy 900cpsi/600cpsi, a w N20 jest to 600/400.
8. Dodatkowy maly katalizator w dalszej czesci ukladu wydechowego (nie monitorowany przez sondy)
9.I taka ciekawostka. Chlodnica pokryta substancja zwana "PremAir" majaca na celu zamiane ozonu w tlen. Krotko mowiac jezdzac po miescie filtrujesz sobie i innym powietrze smile.gif
10. Wiecej nie wiem.
Joker
post Fri, 29 Aug 2014 - 14:04
Ogromne dzięki za info - o takie coś mi chodziło !
SzybkiKuba
post Thu, 04 Sep 2014 - 06:30
I taki szczegół dotyczący Twojego tytułu tematu - tam nie ma bi-turbo (twin turbo). Jest jedna turbina z twin scroll co BMW oznacza twin power. Turbosprężarka jest jedna.
Joker
post Thu, 04 Sep 2014 - 11:23
RSS Wersja Lo-Fi Aktualny czas: Friday, 25 April 2025 - 10:00
